June 22, 2019 at 7:19 am
Astro45
SubscriberHello everyone,
I am attempting to do an impact analysis for a wood based structure in explicit dynamics. But i dont know how to model or map the orthotropic material properties of wood in ansys. I have incorporated the young's modulus (in all three directions), shear modulus (in all three directions) and poission ratio (in all three directions). But still errror comes up solving the explicit dynamic analysis namely as Solver initialization error . if anyone knows how to map the wood properties specially for the explicit analysis,please let me know.
Thanks in advance.
June 22, 2019 at 2:16 pm
SubscriberPlease insert a screen snapshot of the material definition you created in Engineering Data.
June 22, 2019 at 8:36 pm
jj77
SubscriberI tried this and you get this error when using the standard engineering data.
If one uses ACP on shell bodies and define the data there then it is OK - hope this helps.
If you are doing 3D analysis (3Dsolid parts) then it might be more tricky. Then go from explicit to an autodyn system, that will let you define an equation of state (EOS) and thus material that is orthotropic (like wood). The EOS is called Ortho. Of course you might just be able to add it to your orthotropic material (equation of state), and that might work also directly in WB without going to AUTODYN//. I am not familiar with the explicit models so I do not know what equation to use. Perhaps you will find something on the Internet (e.g., ls-dyna and wood).
June 24, 2019 at 3:54 am
June 24, 2019 at 4:02 am
Astro45
Subscriberi tried sharing the setup of the expicit dynamics to the autodyn,and defined the equation of state as Ortho but that also yields the same error.
June 24, 2019 at 7:09 am
jj77
SubscriberIs it a 3D analysis using 3D bodies and 3d say brick elements, or are using surface bodies and shell elements?
For shells we need to use I think ACP see here:
For 3D I am not really sure anymore (I never used the autodyn gui so I do not know anything about it).
The only way I can make it work is if I do as shown below, this I link it up like that (only steel defined in engineering data), I create ortho material in autodyn (say just loaded from a library a ortho-material called kfrp or kevlar), reassigned that to the component (via a fill operation, so setup, component,fill, and material).
I run that and it worked - I do not have a clue how to post process in autodyn, and it is not straightforward to find.
Perhaps someone else has some better tips - or write to ansys support and ask on how to best model this.
June 24, 2019 at 3:52 pm
June 24, 2019 at 5:45 pm
jj77
SubscriberHow did you do that. When I tried adding eos linear to an orthotropic material say s glass, the the orthotropic properties are crossed out, there is a line across orthotropic. -
June 25, 2019 at 2:25 am
Astro45
SubscriberI just created my a new material adding the density and orthotropic elasticity and then the EOS. is that the correct method? if i am wrong please correct me.
Thanks in advance
June 25, 2019 at 5:55 am
jj77
Subscriber -
June 25, 2019 at 8:21 am
June 25, 2019 at 8:30 am
jj77
SubscriberI really believe so - look on explicit library in eng. data and one can see there is no isotropic/ortho. elasticity + eos, it is only eos with strength and failure models.
So the only way as I can see is to use AUTODYN as I did.
June 26, 2019 at 6:55 am
Astro45
SubscriberIs there any way to solve it in LS Dyna extension.If possible Please tell me how to add the orthotropic material properties in that.
Thanks in advance
June 26, 2019 at 10:35 am
June 26, 2019 at 12:24 pm
jj77
SubscriberI have spoken to people that know autodyn and ansys very well, and you can do orthotropic elasticity in Engineering data for Explicit dynamics + orthotropic stress limits for failure but you can not use the nonlinear EOS options or the orthotropic plasticity as you can in Autodyn (as shown above). So unless you do high vel. impact or blast that should be OK. If you do blast or high vel. impact then use autodyn gui as mentioned.
June 27, 2019 at 5:14 am
Astro45
SubscriberThanks for the reply sir.
3682
2552
1751
1232
584
