LS Dyna
LS Dyna
Impact Load Analysis
    • PrabhuManickam
      Hi,nI want to run a Impact analysis, 120 N of hammering load acting on a Aluminium clamp for 5 to 10 times then want to check the deformation and stress of the Clamp.n
    • peteroznewman
      Read this discussion.n
      Hi all.I have to simulate an impact of a pendulum on a test piece. Normally, it wouldn't have any problem, but the impact has to be repeated. That is, the pendulum strikes the specimen, returns to the initial position, and strikes again. This process is repeated for X times. Which tool can I use to perform the test? Explicit dynamics? Static structural? I really don't know...Thank you very much.https://forum.ansys.com/discussion/20408/which-tool-should-i-use
