Impact of the topology estimate factor on results
    • CatiaV5
      Hi guys,
      when running my simulation the CFX solver manager exits with an error pointing me to set the estimate factor higher than 1. I was wondering if setting this parameter will have any impact on the accuracy of the results. And how this error arises in first place.
    • seeta gunti
      Go to the convergence control and select estimate factor, set the value to 2. We need to rename that parameter. In your outline tree in CFX-PRe, you'll see a small part labeled "expert parameters" right click this and select "Edit in command editor"
      change the text from this, topology estimate factor = 2 to topology estimate factor zif =2 and then click process. Now re-run the solver.
      Hope this will help.
      Seeta
