Impactor Simulation
    • cfajard1
      I am doing a simulation of an impactor that will break a surface and I have a couple of questions:
      Material: Titanium for the penetrator, surface: Concrete (couldn't find silicate rock properties in ansys, any suggestions?), subsurface: nickel
      2D to 3D topic:
      - I am doing a 2D model with surface bodies, should I put as thickness the diameter of the impactor? I was planning on leaving it as zero or at least 1 cm to explain the reasoning that I was taking a small cross-sectional cut, but I think when I perform the simulation, because of my thickness is zero, it would not give me accurate results.
      Contact topic:
      - I have 2 fins as breakers so that the impactor does not go completely below surface. Ansys tells me that it doesn't support neither bonded or rough surfaces. How would I leave the fins in place? (picture of impactor attached)
      - Between surface and subsurface I am putting also frictional surface, but I don't know the coefficient of friction between concrete and nickel.
      Suggestions:
      -Any suggestions on how to break a nickel surface at a speed of 800 m/s with titanium? should I choose other material?
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      structural mechanics.
      Keyur
    • peteroznewman
