August 27, 2018 at 4:00 pm
bamdadslr
SubscriberHi,
I want to find the input impedance of a rod inside soil using HFSS. I think I should use Terminal solution type, and maybe lumped port excitation. Can someone please help me in this regard, if I am correct? and how should I define terminals?
August 29, 2018 at 7:46 pm
asamaiyar
SubscriberHi bamdadslr,
Yes driven terminal should work (HFSS > Solution Type... > Terminal).
Create a monopole on a ground plane as shown below.
Create Lumped port on port sheet as shown below.
Now just cover the submerged part of rod with soil material as shown in figure below.
Plot smith chart to get input impedance.
Hope this helped.
Thanks,
Aman
August 31, 2018 at 1:37 pm
bamdadslr
SubscriberHi asamaiyar,
Thank you so much for your help and detailed explanation. It solved my problem with HFSS.
September 1, 2018 at 9:37 pm
bamdadslr
I think the distance of the earth from our electrode and also the dimensions of the earth will affect the impedance of the rode, am I right?
So we have to find a limit for these two values in which the impedance value will converge to a specific value.
September 5, 2018 at 8:22 pm
asamaiyar
SubscriberYes. That sounds correct.
September 5, 2018 at 8:26 pm
bamdadslr
SubscriberThanks. Is there any way to solve the memory issue on HFSS? I increased the number of meshes to get a better accuracy, but run out of memory.
September 7, 2018 at 2:53 am
asamaiyar
This post might give some answers (link).
I would recommend you start a new post about this if you want recommendations from larger audience.
--AS
September 7, 2018 at 1:41 pm
bamdadslr
Thank you so much for your response.
- Maxwell, HFSS or Q3D?
- Error
2630
2106
1333
1110
461
