April 6, 2023 at 7:46 pm
Sushant P
SubscriberI am trying to simulate hydrulic jump for laminar as well as turbulent condition in 2D. I have different nozzle sizes and different spacings from the target plate. The size of the target plate is 20 times the nozzle diameter. I also have enough entry length to get a fully developed flow at the nozzle exit.
I have turned on VOF model for particle and using k-w SST with LRC for turbulent models. I am doing a transient simulation with a time step of 5e-5.
For the laminar models, I get a floating point exception when I turn on Surface Tension modeling with constant 0.072 for water (I am using air and water).
On turning off the Surface Tension I do not I get a jump but instead a thin film that goes all the way to the outlet.My question is about Surface tension. Is there any special thing that I need to do with the Surface Tension. I have seen in some literature the mention adding phase angle but I am not sure how to do that.
Also, if you have any experience with modeling turbulent jets please let me know.
April 11, 2023 at 2:39 pm
April 11, 2023 at 7:03 pm
Sushant P
Subscriber -
April 12, 2023 at 12:22 pm
Ansys EmployeeOK, main problem is cell aspect ratio. Boundary layer meshes are designed for flows where nothing changes along the cell. With multiphase we can't make that assumption, and especially when the film forms & you get waves. Aim for a mesh with a much lower aspect ratio. Then look at adaption (refinement) for the near wall region.
The other thing to consider. Should you be using 2d or 2d axi-symmetric to model a jet?
5162
3275
2453
