Implement a moving heat flux load (circle area) in Ansys Workbench via APDL command
    • HollyFart
      I’m trying to implement a circle shaped heat flux with uniform (constant value) on a simple steel plate.
      The circle shaped load moves along Y direction.
      The circle is the result of nodes gathered from a surf element created in the first step.
      Model:
      Model
      Step 1:
      Step 1
      Step 2:
      Step 2
       Code:
      Step 1:
      /prep7                                 ! Enter into /prep7 as ET and ESURF are valid only in /PREP7
      et,101,152                          ! Create a new element type for SURF152
      cmsel,s,surface1                ! Select nodes on a face via Face named selection
      type,101                             ! Set the element type as 101
      esurf                                   ! Create surface effect elements on the selected nodes
      allsel,all                              ! Select everything back
      /solu                                   ! Re-enter /SOLU
      wpcs,-1,0                     ! WP @ GLOBAL ORIGIN
      wpof,,0.005                  ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
      cswp,11,1                     ! DEFINE Cylindrical COORDINATE SYSTEM @ WP ORIGIN
      esel,s,ename,,152       ! Select SURF152 elements
      sfed,all,,hflux               ! Delete old flux if any
      nsle                              ! Select nodes attached to selected SURF elements
      nsel,r,loc,x,0,0.005      ! Select nodes within radius of circle, 0.005m
      csys,0                          ! Set CSYS back to global
      esln,r                           ! Select SURF elements attached to the nodes within the circle
      sfe,all,,hflux,,1000    ! Apply hflux based on your calculation at the said time
      allsel,all
      outres,all,all
      Step 2:
      wpof,,0.01                   ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
      allsel,all
      outres,all,all
      Something is missing, there is no flux applied on the SURF152 thermal elements.
      Do I use an improper surf element?
      Best regards,
      HF
Viewing 0 reply threads
