Ansys Free Student Software
Implementing mass transfer UDF
    • Pablo Ale Martos
      I have a quick question. After selecting my UDF, the name of my UDF ("liquidtogas::libudf") is shown in the box under "user-defined" (see first picture), but when I click apply, the name of my UDF ("liquidtogas::libudf") disappears (see second picture). Is this normal or does this suggest there is a problem with my UDF?
      Thank you in advance for your help.
      You can see the name of my UDF in the box under The name of my UDF has disappeared.
      Which version are you using?  If you "Apply" then switch tabs & return does the label reappear?
    • Pablo Ale Martos
      I am using 2022 R2. No, if I "Apply" and then switch tabs, the label does not re-appear.
      Odd, it was a problem in an old build but I'd not seen it recently. Whilst I can't say for certain, there's a good chance it's a GUI glitch. See what Solution>Input Summary returns (ribbon menu).
Viewing 3 reply threads
