June 12, 2023 at 7:41 pm
mahzad sadati
SubscriberHello,
I segmented the skull bone in Mimics software and created the 3D shape of it and now I want to import it into Ansys to model it. But when I imported it in SpaceClaim and for converting to a solid model, I got Ansys not responding message. Do I need to do anything before importing my model into Ansys? or for example, should I create a mesh model of it in 3-Matic and then import it into Ansys?
June 13, 2023 at 6:51 am
Sampat Kumar
Ansys EmployeeHi mahzad,
I am recommending some following points that you can look into it.
1. please check your system’s ram size, there might be the possibility that it is stretched.
2. Please check the error in the imported geometry in SpaceClaim and Clean the geometry before converting it into the solid model.
3. you can create the mesh model of it and then import it into Ansys.
SampatHow to access Ansys help links
4438
2951
1427
1322
