February 20, 2022 at 5:10 pm
Jackely
SubscriberHello dear community,
I have found an example of a model I have always been looking for on the internet.
February 21, 2022 at 10:15 amErik Kostson
Ansys EmployeeHi
It is not possible to import an abaqus assembly of parts and instances into mechanical.
So the file called crimp_assembly.inp can not be imported.
All the best
Erik
February 21, 2022 at 12:35 pmJackely
SubscriberHello
Thank you for your answer.
I will then model and simulate this in ANSYS.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5242
3285
2467
