November 9, 2020 at 3:17 pm
Samir Kadam
Ansys EmployeeHow to import Abaqus file with multiple parts within it ?n -
November 9, 2020 at 4:50 pm
Ashish Khemka
Forum ModeratornAnsys won't import Abaqus files written in the assembly format.The Abaqus file will have lines such as *Assembly, and several *Instance lines after that. There will be multiple *Part sections, each containing a *Node and *Element section. The node and element IDs will begin at 1 for each section, and Ansys won't allow the duplicate ID's. You can write out from Abaqus in a flattened format. Another solution is to separate each *Node, *Element section of each *Part into a separate file. Use Multiple External Model systems linked to one downstream Mechanical Model system (Ansys model assembly mode). If you want to retain the *nset and *elset sections, move them to the appropriate file for the part instance they reference and delete the instance terminology after the *nset and *elset commands.nnRegards,nAshish Khemkan
- The topic ‘Import Abaqus file’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1688
1478
