March 28, 2021 at 7:29 pm
NadjouaB
SubscriberHello,
I need to create AS4-3502 as a new material in ANSYS, and these are the only properties that I have. I know that these were enough to use in abaqus but I don't know if for the same simulation (simulation of transverse crack and delamination of this material under a uniaxial tensile stress) in ansys these same properties would still be enough. If they're not enough, could you please suggest to me a way to get the needed data and import it to ansys ? Thank you.
April 19, 2021 at 3:43 pmKai
Ansys EmployeeHi, you will need to define fracture criteria in order to model fracture and **** propagation in Ansys. Please search for ansys fracture to find tutorial on how to simulate fracture in AnsysnApril 19, 2021 at 3:57 pmGovindan Nagappan
Ansys EmployeenUsing this reference https://www.sciencedirect.com/science/article/pii/S002076831000404XnT is the thickness direction. This corresponds to Z in Engineering data (EZ)nL and W are in-plane directions which could be X and Y directions in Engineering data (EX, EY)nIn Engineering data, you need to specify all 9 properties.nExample:n
You can compute the missing propertiesnCheck this help page and see if it helps: 2.1. Structural Fundamentals (ansys.com)nn
April 19, 2021 at 4:02 pmNadjouaB
SubscriberThank you nViewing 3 reply threads- You must be logged in to reply to this topic.
2726
2156
1359
1150
462
