3D Design
3D Design
import CATIA geometry parameters into ANSYS Workbench through batch commands
    • prapa
      Hej
      I am currently working on a project which requires to import parameters created in CATIA V5 into ANSYS Workbench using batch commands and run the simulation there on. Needed some urgent help with this as I was not able to figure a workaround. Note: This process cannot be performed using a third party app
    • prapa
      Normally, its not reflecting the original parametrization in the design modeler. I have tried using the DS prefix too but it does'nt work.
    • Aniket
      This needs a third-party app (CADNexus CAPRI CAE Gateway V3.60.0) as mentioned in the help.
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ref_cad/cadCADNexusCAPRI.html
      -Aniket
    • prapa
      Is there no alternate way to execute this process? Maybe programatically?
    • Keyur Kanade
      You can not import parameters without third party.
      As workaround, please use SpaceClaim. Here you can create your own parameters.
      Please check help document for creating parameters using groups.
      Keyur
Viewing 4 reply threads
