May 31, 2022 at 3:56 pm
lalolanda6
SubscriberHello, I hope you get my point. I'm sorry if you don't, but please understand English is not my first language.
the trabecular bone model come from mimics, a .stl file, 3 matic convert the .stl file to .cdb, then import the .cdb file in ansys . that's a work from 2018(ansys 18.1), and today i need to do the same.
i have to ways;
1)i import the .cdb file in ansys with external model and then go to static structural, but dont recognize like a solid and have intersections of the body
2)i dont find the 3-matic license/crack(long search) , so i have to replace this software with any do the same work , try with fusion 360 but when open in ansys i have interseccions in the body
attached image of problem 2
December 6, 2022 at 6:16 am
bhagwantP
Ansys EmployeeHello lalolanda6,
Looks like your problem is still unclear. Will you please eloborate more may be through screenshots/image attachements?
Thanks
December 29, 2022 at 6:28 am
bhagwantP
Ansys EmployeeFor inserting images you may use attach image option at bottom of the taskbar.
3744
2573
1795
1236
594
