November 14, 2018 at 6:28 pm
Edem930527
SubscriberHello!
I'd like to simulate a transient thermodynamic problem.
I have a heat changer with cooling water and ethanol-water alloy. I'd like to add the alloy temperature and the time contact from an excel file. The simulation is 90 minutes and I determine the temperature every minute (inside this excel).
How can I import this excel to Fluent?
November 15, 2018 at 5:02 am
Keyur Kanade
Ansys EmployeeExcel can be used through workbench for driving input and output parameters.
But in your case I think you will need to write UDF.
Please check customization manual in help.
December 2, 2018 at 5:33 pm
Edem930527
SubscriberI wrote a UDF, but I think it doesn't work.
I'd like 3D simulation, the start temperature is 351,3K (78°C) and then the temperature arises every sec.
Can you check it?
#include "udf.h"
DEFINE_PROFILE(temp, t, i)
real x[ND_ND];
real x0;
face_t f;
real time= CURRENT_TIME;
begin_f_loop(f, t)
F_CENTROID(x,f,t);
x0 = x[0];
if (time<1800)
F_PROFILE(f, t, i) = 351.3 + 0.01 * x0;
else
F_PROFILE(f, t, i) = 373;
end_f_loop(f, t)
December 3, 2018 at 8:51 pm
DrAmine
Ansys EmployeeYou want the temperature to rise every second so why you are using the x-coordinate there. If your temperature profile is only time-dependent just read a transient table or transient profile for that
December 3, 2018 at 9:45 pm
Edem930527
SubscriberThank you for your answer!
Can you write an example what you though?
Best regards,
Adam
December 4, 2018 at 4:29 am
Keyur Kanade
Ansys Employeehere is a example for profile
((sampleprofile transient 3 0)
(time
1
2
3
(u
10
20
30
2656
2120
1347
1118
461
