June 15, 2023 at 9:19 pm
Yushu Zhao
SubscriberHello,
Currently, I am using Ansys 2023R1 Q3D for designing. Now, I want to switching to Ansys 2022R2 Q3D to continue my design. However, I cannot open my .aedt file which create by Ansys 2023R1 in Ansys 2022R2. The error message is: project is created with parasolid geometry kernel. It cannot be open by electronic desktop using ACIS geometry kernel. Is there anyone know how to solve this problem?
Best
June 16, 2023 at 6:50 am
Reshmi Raghavan
Ansys EmployeePlease note that the files once solved in 2023 version will not be compatible with the lower version.
If the original file was from a lower version (2022R2 or lower) and then simulated using 2023R1 a back up folder would be created (with a copy of the older version file) automatically in the main folder. The back up file can be used to simulate in the older version.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7690
4484
2957
1435
1322
