Import Fluent results in Mechanical APDL
    • Docscap
      Hi
      I'm studing a hydrofoil and I follow the FSAE aerodinamics tutorial for the fluid-dynamics analysis to know the stresses. I used the tetragonal mesh to make possible to import the files in Ansys Mechanical APDL but I wasn't able to do that.
      I want to know if it's possible to import the pressure field of a particular foil surface in APDL and if it's possible how to do.
    • Ashish Khemka
      Any reason you want to import it to APDL? You can look into the following video of importing the model in Ansys Mechanical. Ansys Mechanical has a better and more user-friendly GUI.
      " target="blank">Ansys-Uçak Kanadı Analizi (Aircraft Wing Analysis) - YouTube
      Regards Ashish Khemka
  • Docscap
    Thanks for reply. I want to import it to APDL because I want to know what's the effect of the water flow in the foil to obtain the forces and pressures.
    Am I wrong? There's other way to do that?
  • Erik Kostson
    Hi as mentioned
    It is much easier to do this inside workbench by simply coupling a CFD system and a Static System as shown below - this will transfer forces from the cfd system to the static system where we can look at the deformation of this structure due to the fluid flow :
    All the best
    Erik
  • Viewing 3 reply threads
