May 12, 2022 at 6:23 pm
fatemeh.hosseini
SubscriberHello everybody.
I use EDEM-Fluent coupling.I study agglomeration and deposition of particles in a turbulent flow in a tube. I want to import geometry from Ansys. (I used a simple cylinder without any thickness for the wall in spaceclaim.)
As I import the cylinder in the EDEM it seems as a solid, so no particle can enter to the tube.
(Although I have a name selection as inlet-outlet- wall in spaceclaim there are not shown in EDEM)
Can I create fluid domain in spaceclaim or Ansys meshing?
May 13, 2022 at 6:29 amKishan Konannavar
Ansys EmployeeHello
Hopefully exploring the features of spaceclaim and fluent meshing that allow for volume extraction may help. There are some youtube videos also available demonstrating those features.
6.2.8. Enclosing Fluid Regions (ansys.com)
Extracting Volume (ansys.com)
How to make Volume extract ÔÇö Ansys Learning Forum
Regards
Kishan
May 13, 2022 at 8:54 amRob
Forum ModeratorTo add, EDEM takes care of it's own geometry so check what that'll read. Ansys Rocky just reads the Fluent case file!
Viewing 2 reply threads- The topic ‘Import geometry from ansys to EDEM’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
