Ansys Products
Ansys Products
Import geometry – Surface bodies
    • cskbdia
      I imported a .iges file from fusion to ansys but when it is generated, 28 surface bodies appeared instead of 1 solid body. I can't use the boolean command because of this. Please give any insight and fix
    • Nikhil Narale
      Hello Cyril,
      You can use 'Stitch' command from the Repair tab in SpaceClaim or Discovery to create a body out of the surfaces.
      Nikhil
      • cskbdia
        I opened the file in Spaceclaim and was able to repair them, But the next problem is a failed boolean and a prompt for "Conversion of body to DesignModeler format failed". I am now looking for workaround this warning. (Sorry if this is an obvious problem/fix I am still new to ansys fluent)
