October 21, 2023 at 1:29 pm
Rizqinta Febiantari Purnama
SubscriberWhen creating geometry in other software, is there a special way that geometry can be used in Ansys?
October 21, 2023 at 2:13 pm
Alvin Evandiaz Audhia
SubscriberHello rizqinta, I think it can be used if the file type is the same
October 22, 2023 at 8:00 am
Raihan Lutfianto
SubscriberHi Rizqinta and Alvin. Please use a "neutral file" format, such as .STEP or .IGS (I personally recommend using .STEP).
October 23, 2023 at 4:42 pm
VJ
Ansys EmployeeCAD neutral formats like IGES, STEP or STL should work.
- Difference Between Force and Remote Force
- Features of the check case
- Room with Air-Conditioning Vents
- Error Floating Point Exception
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Heat transfer radiation through glass
- Convergency in mass flow rate
- real fundamental difference in true tension body and engineered tension
- Torsion Stiffness
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
8762
4658
3151
1678
1456
