Preprocessing
Preprocessing
Import .ipt file in Design Modeller
    • Siddharth98
       I'm trying to import a .ipt file of a perforated pipe (figure attached) in design modeller but getting several error messages as follows:
      1. No compatible interface found for this file type
      2. Geometry interface not found
      3. Attach failed.
      Although I was able to import in Space Claim, I couldn't assign fluid body to interior of pipe there and also couldn't find symmetry feature.
      Please suggest some methods.
      Thanks,
      Siddharth
    • peteroznewman
      After the Geometry successfully imports into SpaceClaim, close that program. In Workbench, right click on the Geometry cell and Open with DesignModeler.
    • Siddharth98
      After opening geometry in design modeler, I'm unable to fill hollow space for fluid entity. Besides fill option, I've also tried Volume extract option in Space claim but the file couldn't be saved then (exceeded geometry limits). I'm attaching screenshots of the same.
      Without following above steps, I can't mesh fluid body. Please give some suggestions.
      Thanks a lot,
      Siddharth
    • Keyur Kanade
      please check
      Another option is copy weted surfaces and cap them. then use sew command in design modeler or stich command in spececlaim.
      Keyur
    • Siddharth98
      After completing meshing of the geometry, I am facing following problem in Setup Launcher.
      Please help
      Thanks
      Siddharth
    • Keyur Kanade
      with student version the limit of no. of cells is 512K.
      you need to mesh your model so that you have max 512K cells.
      Keyur
Viewing 5 reply threads
