July 30, 2019 at 9:40 pm
guimilan
SubscriberHi everyone,
I'm doing FSI simulation in ANSYS 17.2, and meshed both the solid and the fluid domain in GAMBIT 2.4.6. I have no problem in importing the fluid mesh in Fluent, while to import in Mechanical it's a bit tricky. I export the mesh from GAMBIT, then import it in the External Model component system and share with the Transient Structural system. My questions are:
- Can this tricky process compromize the simulation, like causing a mismatch at the fluid-solid interface?
- Is there any way to import a mesh directly from GAMBIT to the Transient Structural block?
Thank you for your help!
July 31, 2019 at 10:09 am
Ansys EmployeeGiven GAMBIT hasn't been developed in about 10 years and R17 is 3 years out of date I'd suggest updating to 2019R2 when you can.
If the mesh is transferred then there shouldn't be a mismatch. If you're remeshing that's likely to not match. How are you controlling the FSI data transfer?
July 31, 2019 at 1:37 pm
guimilan
SubscriberThank you for your answer rwoolhou,
I am doing remeshing at each iteration. Data transfer are force (under relax factor 0.3) and incremental displacement. Is that what you meant by controlling the FSI data transfer?
Best
August 1, 2019 at 10:22 am
Ansys EmployeeNot quite: what transfers the data from Mechancial back to Fluent?
August 6, 2019 at 3:17 pm
guimilan
SubscriberI guess is the System Coupling that tranfers data. Anyway I tried to run the simulation and it seems to work with no problem.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
