Import mesh from TurboGrid
    • Gonzalo_RH
      Hello everyone,
      I have a problem when transfering a mesh from TurboGrid to Fluent. As you can see the grid is validateed and there is no any warning in the TG module. The maximum number of cells for the academical license is not exceeded.
    • rfblumen
      Try this:
      -Break the connection between TurboGrid and Fluent on the WB project schematic
      -In TurboGrid, go to File->Export Mesh...
      -Save the mesh with a .def extension to the User Files folder in WB
      -In Fluent, go to File->Import->CFX->Definition File and point to to .def just created
    • Gonzalo_RH
      THANK YOU VERY MUCH!!!!!!!!
