September 12, 2019 at 11:20 am
pinkerthoms
SubscriberHi,
I'm currently working on a CST parametrization for airfoils.
To achieve this parametrization, a python script has been written. This script uses numpy and scipy functions, and works well when it is launched on Anaconda Spyder.
However, these modules are not available in SpaceClaim. So I try to copy/paste numpy and scipy's folders inside ANSYS one, and launch :
import sys
sys.path.append("C:Program FilesANSYS IncANSYS StudentCustomlib")
import numpy
But I have this error : cannot import _mklinit from numpy
Can you help me to import them ? Or maybe is there a way to call Spyder inside SpaceClaim ?
Thanks,
Thomas. -
February 5, 2020 at 10:44 am
pinkerthoms
SubscriberA solution here : https://forum.ansys.com/forums/topic/script-in-spaceclaim-problem/
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
