November 16, 2017 at 11:20 pm
dmendez-granular
SubscriberHow I can import any parameter from workbench to fluent? I need ,among others, to import a geometric value parametrized in workbench and use it like variable in fluent.
Thanks in advance.
November 21, 2017 at 12:03 am
November 21, 2017 at 2:11 am
November 21, 2017 at 2:40 am
Min Zhang
SubscriberThis just makes the parameter ("ChannelRe" ) become one of design or input parameters. Fluent can also realize this.
But "ChannelRe" is just then listed in the "Parameter Set" Tab, while it cannot be directly used by other systems (like fluent, geometry). We could not create parameter relationship in the "Parameter Set" Tab.
November 21, 2017 at 2:09 pm
Jimmyhan
SubscriberWhat about CFX?
November 24, 2017 at 5:43 pm
dmendez-granular
SubscriberThank you
With your help and the ansys help I could do it.
It is posible defining a scheme proc with lambda command using the same name of the variable that is in workbench.
I m doing a PhD about continum granular models and i'd need another thing...
I don´t know how to extract the value of the coefficient of restitution for use it like field function in "custom field functions". I'm not sure if this is posible...
Thanks a lot.
2706
2146
1357
1148
462
