Import results of transient thermal analysis
    • Nagham
      Hi, I am trying to import the results of a transient thermal analysis into another one ( I didn't do that by steps in the same transient analysis because I wanted to change the geometry in the second transient thermal analysis). However, when exporting the solution in the second transient thermal analysis, I didn't knew where can i change the imported temperature from boundary conditions (proceeded automatically) into initial conditions. I am working in workbench 19.
      Thank you for your help,
      Regards, Nagham
    • 1shan
      If you are importing the temperature using external data you can set the apply as property to "Initial condition" as shown
      Regards Ishan.
    • Nagham
      Thank you Ishan
