January 10, 2023 at 9:12 pm
ha_nguyen3
SubscriberHello,
I want to import a rat phantom in DICOM format into Ansys HFSS for electromagnetic simulations. Is it possible to do so? If I need to convert the DICOM file into other formats (listed below), what softwares are recommened for the conversion?
I also want to change the voxel values. I believe this can be done after importing the phantom into HFSS and assigning material properties. Is it correct?
Thank you.
January 18, 2023 at 3:48 pm
Jesse Dk
SubscriberIs there a way to obtain and export the complex radiation pattern of an antenna to a vidmate file?
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1349
1118
461
