Ansys Products
Ansys Products
ImportException: No module named picamera
    • Shubhamhegade1234
      What are you doing when this error is triggered?n
    • Shubhamhegade1234
      I tried to install python libraries as seen in that workbench_server_utils.py. But Ansys uses IronPython as its backend python interpreter as can be seen in the error.nInstalling dependencies with IronPython is very difficult.nMoreover, picamera module works in Linux distributions only. I had used picamera libraries in a Raspberry Pi. Raspberry Pi OS is Linux-based I think.nWhen I tried to install picamera with pip in Anaconda prompt, it doesn't work. nAnd obviously, Ansys doesn't use Anaconda. It used IronPython.nThis error has been consistent in my laptop with 2017, 2019, 2020 versions of Ansys.n
