Discovery Import
Discovery Import
Importing AutoCAD 2016 2d files – Issue about scale
    • inetzi.s
      After having saved an AutoCAD Architecture 2016 2d drawing as .dxf format, I opened it in Discovery Live Student, by using "import". Although I checked all options concerning association of units, the drawing is being inserted scaled. That is to say, every 1,00 m of AutoCAD is translated as 1,00 mm in Discovery. So my drawing has been scaled ...
      How can I solve it?
      Is it possible to scale the lines x1000 ? Or have I to remodel directly in Discovery?
    • Waled Raban
      Hello So-Ine , When you have the Open dialog box opened, try filtering your file extensions for AutoCAD (dwg,dxf), and then uncheck 'Try to infer Model Space units' and then choose the Model Space units you desire. You may also scale the lines as an alternative option. See images attached. I hope this helps you.
    • inetzi.s
      Thank you!!
      Really helpful - I solved it!
