3D Design
3D Design
Importing coordinate points in Design Modeler
    • ashiadarsh
      Hi everyone,
      I am trying to import coordinate points to Design Modeler to get a curve. I have  created a text file which contains 5 columns: Group ID, point number, X, Y, Z coordinates. The geometry is 2-D (all Z-coordinate points are 0). I have a simple curve which is not closed. As of now, I am able to import the text file successfully, but when I try to connect the coordinate points using 3D curve option, I get an error while choosing the last few points. This is the error:
      "invalid point selection. The curve would become self intersecting"
      What could be the reason? Any thoughts?
    • Keyur Kanade
      first import points.
      then try to create curve manually in DM. please see if you can create this curve and it is not self intersecting.
    • ashiadarsh
      Dear kkaade,
      This is exactly what I did!!! I cannot simply select few points because of this error. Any other suggestions?
    • raul.raghav
      Can you attach your text file so we could take a look at it?
    • ashiadarsh
      Dear Rahul,
             Please find the co-ordinates as attached below
      1 1 0 52.24540407 0
      1 2 1.996661102 52.26684514 0
      1 3 10.98163606 52.05646348 0
      1 4 19.96661102 51.34393671 0
      1 5 29.94991653 49.96330467 0
      1 6 42.92821369 47.24168432 0
      1 7 55.90651085 43.4723785 0
      1 8 68.88480801 38.65538719 0
      1 9 77.86978297 36 0
      1 10 89.84974958 32.62006653 0
      1 11 99.83305509 3.75E+01 0
      1 12 106.8213689 41.46222806 0
      1 13 117.803005 47.93257399 0
      1 14 128.7846411 54.53939849 0
      1 15 136.7712855 59.381139 0
      1 16 147.7529215 66.03308196 0
      1 17 165.7228715 76.76805847 0
      1 18 182.6944908 86.59246474 0
      1 19 199.6661102 96.00880764 0
      1 20 216.6377295 104.9635754 0
      1 21 231.6126878 112.4668845 0
      1 22 253.5759599 122.8106248 0
      1 23 270.5475793 130.2987116 0
      1 24 295.5058431 140.5996461 0
      1 25 311.4791319 146.8023845 0
      1 26 327.4524207 152.7395059 0
      1 27 351.4123539 161.203113 0
      1 28 379.3656093 170.4680974 0
      1 29 399.3322204 176.6925859 0
      1 30 426.2871452 184.5357946 0
      1 31 446.2537563 189.8790231 0
      1 32 469.2153589 195.4630661 0
      1 33 493.1752922 200.581734 0
      1 34 519.13 205.27 0
      1 35 541.09 208.59 0
      1 36 563.06 211.46 0
      1 37 582.027 213.7782 0
      1 38 600 216.1 0
      1 39 618.63 219.034 0
      1 40 637.1 222.94 0
      1 41 655.57 228.51 0
      1 42 674.03951 236.58 0
      1 43 692.51 248.18 0
      1 44 701 255.043 0
    • raul.raghav
      I changed the units from the default meter to millimeter when I imported the points and it worked fine for me. Additionally, if you add the line 1 0 at the end of the coordinates file, you will get a closed loop. See attached screenshot:
    • AdithyaB
      Hi Adarsh,
      I had a similar error. The fix was to use same format of numbers as used in your ansys; that is if a comma or dot is the correct input for decimal place.
      Adithya
    • Tayyaba
      Hi
      when I import points, i got an error "no of points generated 0". I followed the same steps of importing the .txt file but unfortunately I didn't get points in Design modeler.
      Waiting for any kind answer.
      Tayyaba
      Have you checked the file format?
    • Tayyaba
      It was mistake in my file, I have done it now.
      Thanks
      Tayyaba
    • AhmedZ
      Hello
      Check the ordering of the points, as like to be from the leading edge through the upper surface then from trailing edge through the lower surface, the idea is not to make the curve self intersected.
      you can reorder the points with excel.
Viewing 10 reply threads
