November 10, 2020 at 8:25 pm
soloviev
SubscriberHello,nI was just wondering if I can import a profile with NaN or missing data values into Fluent?.Thanks,nAlexn -
November 11, 2020 at 11:25 am
Forum ModeratorThe profile is a boundary condition, what data is missing? Profiles interpolate to the location they're used, but the data needs to exist in the file to import as there are checks against the number of data points. n -
November 11, 2020 at 3:22 pm
soloviev
SubscriberWe are importing a matrix of data, that has values assigned at x,y,z coordinates, but some of these points do not have values, of have NaNs. I guess we're wondering if Fluent can import and interpolate with these values missing? nThanks,nAlexn -
November 11, 2020 at 4:58 pm
soloviev
SubscriberWe actually tested loading a profile in with both an NaN and a blank value and fluent notified us that the data couldn't be read due to errors.Thanks,nAlexn -
November 11, 2020 at 5:00 pm
Forum ModeratorIt'll receive the data as is and I'm not sure it'll react well to missing values. The profile interpolation is fairly dumb so should throw an error rather than adding random values to the boundary. n -
January 7, 2021 at 5:37 pm
soloviev
SubscriberYes, thank you. We plan to try to interpolate our data before importing to Fluent. n
- The topic ‘Importing data with NaN or missing value’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
