3D Design
3D Design
Topics relate to Discovery SpaceClaim, Discovery Live and Discovery AIM
Importing Line and Solid Bodies from SpaceClaim to Mechanical
    • peteroznewman
      I successfully built a model with solid and line bodies using DesignModeler to study a helical gear mesh.
      I started with a solid shaft that was split in quarters axially in DM to create vertex points along the shaft axis that lines were created on then line bodies were created with a circular cross section.
      Solid and Line Body using DesignModeler
      I'm trying to do a similar model starting in SpaceClaim. I imported spur gear solid bodies and created some lines in SCDM, but I don't know how to define those lines as line bodies with circular cross sections.
      solids and lines
      I guessed that I should create New Components from the lines I drew. I guessed that I should add a Circle profile, which created this Beam object in the outline, but where do I enter the diameter of the circle?
      Beam circle properties
      Finally, when the time comes to import Geometry into Mechanical, I look at the Mixed Import Resolution property, and I can choose solids and surfaces or surfaces and lines. Don't I want solids and lines?  All attempts have only resulted in the solid bodies being imported into Mechanical.
      Geometry properties
      I have attached the ANSYS 18.2 SpaceClaim file in case someone can use it to answer my question.
      Thanks in advance.
Viewing 0 reply threads
