November 17, 2020 at 8:09 pm
Kifflom
SubscriberDear Users,
I have created a transient thermal system and connected a static structural to it. I have conducted the thermal analysis. By default Ansys imports temperature of each node at every substep, but the only results that matter in my case are the maximum temperatures reached over time.
November 18, 2020 at 5:08 amAshish Khemka
Forum ModeratorNovember 18, 2020 at 10:08 amKifflom
SubscriberThank you for your assistance, Ashish.nUnfortunately, since I am using Ansys for academic purposes I do not think I have the access to the page you are referring to.nedit: I found a thread on our forum explaining a workaround to the link access problem. Looking into it. For anyone else having the same issue in the future - here is the link https://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-helpnNovember 19, 2020 at 5:44 amAshish Khemka
Forum ModeratornnThanks for the update.Regards,nAshish KhemkanViewing 3 reply threads- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8700
4658
3151
1672
1446
