October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeCan a Mechanical APDL model be imported into ANSYS Workbench?
October 18, 2017 at 5:44 am
Arun
Ansys EmployeeYes. Workbench can read a MAPDL archived coded database file (cdb file). A cdb file can be written from within MAPDL using the CDWRITE command. You should use the db only option to save only the FE data. You do not want to save the solid model, because Workbench cannot read the MAPDL solid model or cad data. If the model is an assembly, you could create one cdb file for the whole model or multiple .cdb files for each sub-assembly. Note: Workbench cannot import a MAPDL binary database (db) file. It can only read the ASCII .cdb file.
September 20, 2018 at 9:46 am
pradeep
Subscribercan anyone say me the steps to follow to transfer the solved APDL data to workbench , i have done it in with external model then linking it to mechanical model and transferred it to static structural .
but i am unable to do it for transient case is there any other imports that i am missing..
October 5, 2018 at 11:48 am
Ashish Khemka
Ansys EmployeeYou may follow the steps by Arun or the documentation should have the steps required.
Ashish Khemka
3391
2473
1310
1022
