February 22, 2022 at 5:40 pm
hansenli
SubscriberHi,
I am trying to import a meshing file into an LS-DYNA case. This dat file is from Salome. When I tried to import it, it said that it cannot read the file due to wrong file name.
February 22, 2022 at 10:03 pmErik Kostson
Ansys EmployeeHi
The format should be similar to the Nastran deck sample below, otherwise it will not be imported in.
(So how a Nastran file for the mesh looks or should look like (GRID for nodes etc, CHEXA for HEX8 elements, CTRIA,..etc)):
Thank you
Erik
BEGIN BULK
$ NODES ------------------------------
GRID100.0000001.0000000.0000000
GRID200.0000000.0000000.0000000
GRID300.0000001.0000001.0000000
GRID400.0000000.0000001.0000000
GRID501.0000001.0000001.0000000
GRID601.0000000.0000001.0000000
GRID701.0000000.0000000.0000000
GRID801.0000001.0000000.0000000
$ ELEMENTS ------------------------------
CHEXA11134285
67
ENDDATA
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2534
2066
1285
1104
459
