Preprocessing
Preprocessing
Importing mesh
    • Evgenii_K
      Good mood to you all!nThere was a need to transfer the mesh settings from static structural analysis to Composite PrepPost, since there is no direct transfer of the mesh, perhaps there is a way to transfer the settings ?!nn
    • Govindan Nagappan
      @Evgenii_KnnIf the model is the same, you can connect the ACP Pre to an existing static structuralnDrag the ACP Pre from tool box to the Model cell of static. (Notice if you drop in the model cell, it will share engineering data, geometry and model)nnMesh will be shared between the ACP Pre and static structural system. n
    • Evgenii_K
      Thank you very much for your advice, I will try!n
