March 22, 2021 at 3:35 pm
hani.sadek_i
SubscriberHello, nI am trying to export the motor-cad model that I have built to ansys maxwell. nThe problem is that in workbench, after adding and opening the geometry box (Which is SpaceClaim 2020R2) I can't find how to import the javascript exported by motor-cad as explained in the help documentation. nThe only option I get is, inside SpaceClaim and under the design tab, there is a script button that gives me the option of writing a python script. nhelp! please!n -
March 22, 2021 at 10:36 pm
icellb1
Ansys EmployeeHi,nSpaceClaim supports *.scscript and *.py, if you want to import into Maxwell, you can open Maxwell, and then Tools-->run script, that'll allow you to run *.js, *vbs, or *.py.n
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
