January 11, 2023 at 2:36 pm
EdK
SubscriberI'm trying to import a .stl file to define a structure in Lumerical FDTD. This does not work as when I import the file nothing appears, I can see that in the object tree the object is there, but in the view box there is nothing there.
Varying the scale factor does not seem to work. I used the example .stl file from https://optics.ansys.com/hc/en-us/articles/360034901953-STL-import-Simulation-object. This one works fine, so I suspect it is an issue with my .stl file. It works fine in COMSOL, but Lumerical seems to have issues with it.
Can't find a way to upload the .stl file to this post, but I have attached an image of what the .stl file should look like.
Kind regards,
Edk
January 26, 2023 at 6:38 pm
Guilin Sun
Ansys EmployeeIt might be version issue. What stl version you are using?
did you try those:
https://optics.ansys.com/hc/en-us/articles/360034924733
If problem still exists, please send us your stl file together with your solidwork version and software version to the support email.
Later please write your post here https://forum.ansys.com/forums/forum/discuss-simulation/photonics/ for photonics software (Lumerical).
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2614
2088
1321
1108
459
