April 10, 2023 at 6:53 pm
Benhour Amirian
SubscriberHello everyone,
I was wondering if you could help me how to import stress strain curve for material definition in dyna. I am trying to use that for defining composite material.
Thanks.
April 11, 2023 at 5:31 pm
Reno Genest
Ansys EmployeeHello Benhour,
Which material model are you using? Which software are you using to create the model?
Reno.
April 13, 2023 at 5:09 pm
Benhour Amirian
SubscriberHi Reno,
Thanks for your reply. I am new to LS-Dyna.
I am using LS-Prepost for creating the model and I need to simulate a simple 2D model under uniaxial tensile loading. Suppose that I am using a linear elastic model.
Bests,
Benhour
April 13, 2023 at 6:02 pm
Reno Genest
If you are using a linear elastic model (*MAT_001 in LS-DYNA), you don't need stress-strain curves. Only density, young's modulus, and Poisson's ratio.
Importing a stress-strain curve makes sense for a material model with plasticity such as *MAT_024 (for modelling metals).
Reno.
April 13, 2023 at 6:37 pm
Benhour Amirian
SubscriberThanks Reno for your quick response.
Actually, I need to mdel a single element composite matrial, which I believe I need to use MAT_052. Besides, suppose that I am creating a model for MAT_024. What is the approach for importing the stress-strain curve?
I appreciate your help.
Benhour
April 14, 2023 at 9:41 pm
Andreas Koutras
Ansys EmployeeHello,
Are you referring to MAT_054, which is a popular material for modeling composites? MAT_054 does not support direct use of stress-strain data. Instead you can determine the material constants based on your data.
In MAT_024, LCSS is used to define stress-strain data in terms of effective stress -vs- effective plastic strain. When LCSS references a load curve, the curve of the stress-strain data is defined with *DEFINE_CURVE. Further details are shown in the section of MAT_024 in Manual Vol II https://lsdyna.ansys.com/manuals/
Some examples are available here:
https://www.dynaexamples.com/
https://www.dynaexamples.com/introduction/intro-by-j.-day/misc/mat24-table
https://www.dynaexamples.com/introduction/process_simulation
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
4980
3125
2343
1306
908
