Importing Temperatur from thermic transient analysis to structural mechanical
    • Evangelia Weidmann
      I am trying to import the temperature i have retrieved from a thermal transient analysis to a structural mechanical analysis. There are 875 temperatur steps. Step 1 being at 15s, step 2 at 30s ect.
      The Quellzeit of the imported temperatur should be the same as the Analysezeit. I cant edit the column of the Quellzeit. Until this column is fixed, i cat run the structural mechanical analysis.
      Any help and tipps would be greatly appreciated.
    • Rahul Kumbhar
      Hi @Evangelia,
      What is the error message you get? There is 'Show Error' option under Home tab. Please check and post your reply here.
      The error is "Die importierten Quellzeiten aus der Temperatur sind ungültig".
