September 4, 2023 at 12:27 pm
bbcn
SubscriberHi everyone,
DoE has created the below design points:
However, I have been having trouble to get output parameter results by using DoE. Thus, I have analysed all the design points and obtained the output parameters manually. Since I have all the output data, I would like to input those output parameters into the Responce Surface Optimization again to do the optimization. Is there a way to input the output parameter data into the Response Surface Optimization so that I can evade DoE solver? Because I have all the results, all I need is that all those data to be optimized.
Thank you.
September 5, 2023 at 3:22 pm
September 6, 2023 at 2:40 am
- How to move duplicated ansys project position in workbench GUI
- unable to open files in ansys
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Error: Unable to open some designs in this project – Corrupted project files
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- How to export high resolution images in APDL
7690
4476
2957
1435
1322
