March 9, 2023 at 8:40 am
Filip Stenström
SubscriberHi,
I am a student how write my master thesis. I will model various bridge typs using mostly SHELL181 elements. However, I want an efficient way of creating and adjusting geometries into the ANSYS MECHANICAL ENTERPRISE. My intial idea was to creat geometries in Spaceclaim, export as .anf file and then using /input, gemotry.anf. This doesn´t work unfortunally.
In previoud example file i got they wrote sometinhg like this, however I noticed there can be some problems when using .igs files and that it is better to use .anf or .inp files:! Wand 1/AUX15IGESIN, RhinoModell_W1, igs ! Import Rhinomodell/prep7NUMMRG,ALLasel,s,loc,z,-0.01,-100000asel,u,loc,Y,2,100000aovlap,allNUMCMP,areaallsel
If someone could show me how to do that it would be healpfull.
Thanks beforehand. -
March 10, 2023 at 4:26 pm
Bill Bulat
Ansys EmployeeHello Filip,
One thing you might consider is to locate the Help articles shown in the image below and try a number of different available options for importing geometry into MAPDL:
If you have an .anf file, I think all you need to do is to read it into MAPDL with the /input command:
/aux15
/input,filename,anf
The following Help article describes .anf file contents/format:
but I don't see the simple instructions regarding how to read it in. So I'm not 100% certain, but I suspect what I have above is correct.
Kind regards,
Bill
3694
2564
1765
1234
590
