September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow to imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler?
October 17, 2017 at 7:48 am
Arun Kumar
SubscriberTo work with baffles in ANSYS Spaceclaim Direct Modeler, Volume bodies and Surface Bodies have to be generated/moved in 2 different components at the upper level. To imprint the baffles on the volume bodies, the Share topology option has to be set to Merge between the 2 main components. Example: Design (-> Share Topology : Merge) - Component1 (-> Share Topology : Share) -> Volume Bodies - Component2 (-> Share Topology : None ) -> Surface Bodies
2616
2098
1321
1108
461
