December 8, 2020 at 7:58 pm
manelaero2020
SubscriberHi freinds ;
1/ If the curves of residuals are oscillating ( please see attached figure) ; so is it true to say that my numerical scheme is INSTABLE ?
2/ In the order to improve the stability of my numerical scheme ( second order upwind + K epsilon RNG for turbulence) and accelerate convergence ; it is a good solution to switch to unsteasy temporel model and decrease the time step ?
Thanks you
December 9, 2020 at 4:33 amKeyur Kanade
Ansys EmployeeIf physics you are solving is inherently transient then you will have to use unsteady solver. nOscillating residuals does not necessarily mean that numerical scheme is unstable. It may depend on your inputs. nAlso please check mesh. Make sure that you sufficient mesh refinement at the areas interested. nYou can find numerical scheme related information at nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- The topic ‘improve the stability of a numerical scheme’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
