March 26, 2021 at 6:47 am
erwin
SubscriberHi I'd like to get some help on improving the mesh of this ASWT for an undergraduate thesis. I've tried using inflation but I see the elements balloon up to more than 1 million elements. I'm using a student version of ansys and I think the limit is around 512k. I'd like to know what I can do to get a good mesh that's around the limit while still being able to use inflation since from my understanding using inflation helps with the solution?
If in any case it would not be possible to use inflation, I'd like to know what other meshing options I can perform to improve the overall mesh quality. Thanks in advance!
March 26, 2021 at 7:40 amKeyur Kanade
Ansys EmployeeYou will need to use different size at different places. You can use face sizing for different faces. Also you can reduce layers to 3. nPlease check following videosnnAnsys Meshing,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 26, 2021 at 5:55 pmerwin
SubscriberThank You Mr. Keyur! I'll look into the video you shared and hopefully be able to address my problem.God Bless!nnMarch 26, 2021 at 6:33 pmMarch 26, 2021 at 7:20 pmerwin
SubscriberHi again Mr. Keyur, I think I have solved my problem and have created a relatively reasonable mesh. I have another question though, as my thesis group will also perform FSI analysis for the turbine, I'd like to know if we would have to adjust anything more on the mesh in order to be able to perform FSI simulation later on or is this current mesh good already? Thanks again!nn
March 30, 2021 at 6:32 amKeyur Kanade
Ansys EmployeeAs I do not have mesh, it is difficult to comment. But in general, it should be good for fsi. nViewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1349
1118
461
