Photonics
Photonics
Impulse Response of System
    • afshiin.a
      Hello.
      We know that by applying an impulse signal to the system, the impulse response of that system is obtained. I want to know how to calculate the impulse response of an arbitrary circuit in Lumerical.
      For example, I want to calculate the impulse response of a microring resonator in MODE or FDTD.
      Thank you for your guidance.
    • Kyle
      The simplest way to do this would probably be to use an optical impulse source (https://optics.ansys.com/hc/en-us/articles/360036107594) then record the output with an optical oscilloscope (https://optics.ansys.com/hc/en-us/articles/360036107134).
      • afshiin.a
        Thank you 🙂
    • Kyle
      Rereading your post, it seems I misread it. When you mentioned “arbitrary circuit” I assumed you meant INTERCONNECT, but if you want to calculate the impulse response in FDTD or MODE then you will need a different approach because we can’t actually use an impulse source. The DFT monitors in FDTD/varFDTD calculate the transfer function by default, which is the Fourier domain representation of the impulse response. I’m not sure of the details, but I believe you should be able to turn this into the impulse response through an inverse Fourier transform. This page has more information on this: https://optics.ansys.com/hc/en-us/articles/360034915813
      • afshiin.a
        Thanks for your attention.🙏
