In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeNo. For a single mode, the ratio to critical is greater at frequencies below resonance and smaller at frequencies above resonance. This is documented in the Structural Analysis Guide Section 1.2.4. You can find the complete equation in the ANSYS Help documentation, under "Mechanical APDL -> Theory Reference -> 14.3.3 equation 14-22 parameter g, mj, gEj". The damping contribution g is related to the damping matrix by [C]=(2*g/Omega)*K. Omega is the excitation frequency. So (2*g/Omega) is a coefficient times the stiffness matrix like Beta damping. Beta = 2*eta/omega (omega is natural freq) while 2*g/Omega = 2*eta/omega: eta (ratio to critical) = g(omega/Omega) In a single degree of freedom test you will see the ratio to critical be higher at low excitation frequencies and lower at high excitation frequencies. A 1 dof test is provided below. Note that you can't measure the damping ratio by dividing the imaginary solution by the real solution. For example, at resonance, that is infinity, not any measure of damping. The only method I know is to compare the dynamic response to the static response. At resonance, the "dynamic load factor" will be 1/2*eta, where eta is the ratio to critical. The formula for the dynamic load factor at other frequencies is: 1/SQRT[(1-OMEGA^2/omega^2)^2+4(eta*OMEGA/omega)^2] Away from resonance, the harmonic response is not a strong function of damping, so the deviation from ratio to critical is small. /prep7 et,1,14 et,2,21,,,2 r,1,100*(2*3.1416)**2 r,2,1 n,1 n,2,1 e,1,2 type,2 real,2 e,2 d,1,all d,2,uy f,2,fx,1000 mp,dmpr,1,1.0 fini /solu antyp,static solve ux2=ux(2) ! static displacement = 0.253 fini /solu antype,harm harf,0,20 kbc,1 nsub,20 solve fini /post26 nsol,2,2,ux prcplx,0 prva,2
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
