March 25, 2022 at 3:58 am
Nycbros
SubscriberI successfully ran a simulation in Q3D and then I imported into Mechanical. I ran the thermal simulation but got an error "Simulation completed with execution error on server."
Any advice on this is appreciated.
March 25, 2022 at 3:59 amViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
