March 24, 2021 at 2:14 pm
Mukka_Srikanth
SubscriberIn my project while doing fatigue analysis of ball and socket joint for hip implant,
March 24, 2021 at 8:30 pmBhargava Sista
Ansys EmployeeHigh friction (typically coeff. of friction higher than 0.2) between surfaces can make the stiffness matrix unsymmetric. Sometimes, such cases may face convergence issues in which case using an unsymmetric Newton-Rapshon solver is helpful. In your case, if you did not run into any convergence issues and have a solution (all green check marks on model tree), then you may ignore this message. If you run into convergence issues, then changing the Newton-Raphson option (Analysis Settings --> Nonlinear Controls --> Newton-Raphson Options) to Unsymmetric could be helpful.nMarch 27, 2021 at 5:59 amMukka_Srikanth
SubscriberYeah it was helpful...thank you for detail answernViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2150
1359
1150
462
