In CFX and Fluent, is “mass flow” set under normal or operating conditions?
    • offroader10052
      Hello.nPlease tell menin CFX and Fluent mass flow (kg / s)non the input boundary conditions tabnis asked under normal or operating conditions?nFor a liquid, this is not usually important.nIt is very important for gas.n
      Mass flow boundaries will add that amount of mass at the boundary conditions specified. So, you need to be careful with the pressure & temperature etc for compressible gases. n
    • offroader10052
      Thanksn
    • offroader10052
      I understood like this:nGiven:nVolumetric gas flow rate under standard conditions (temperature 25 ?C, pressure 1 atm).nTask 1:nDetermine the mass flow rate at a temperature of 50 ?C and a pressure of 10 atm in the apparatus.nTask 2:nEnter the obtained mass flow rate into the ansis.nSolution step by step:nStep 1.nRecalculate the volumetric flow rate (m3/s) in Excel under operating conditions (temperature 50 ?C, pressure 10 atm).nStep 2nRecalculate in Excel the mass flow rate (kg/s) according to the obtained volumetric flow rate under operating conditions in the previous step.nStep 3:nEnter the obtained mass flow rate into the ansis.nLet it be useful to someone.n
      Also remember if the pressure doesn't change much in the domain that you can alter the material density etc and ignore the pressure. n
Viewing 4 reply threads
